The Meinberg Network Management System is an out-of-the-box NMS solution that runs on standard DataMiner software and is sold by Meinberg. Created from a partnership and joint development between Skyline Communications and Meinberg, this central platform automatically detects, provisions, and monitors all Meinberg applications. mbgNMS is based on the DataMiner platform and is dedicated to Meinberg products.
Meinberg NMS V1 supports all LTOS devices starting with 7.04.009 firmware. To download the Meinberg Element Manager app package, click the appropriate link in the table below, which also shows the corresponding compatible DataMiner version. To avoid possible issues, make sure you always use compatible versions. Please refer to the Meinberg NMS manual and release notes for detailed instructions.
Meinberg Element Manager app version | DataMiner version | Meinberg API version | Meinberg firmware version | Release notes |
1.0.0 | 10.1.7 | 8.6.x | 7.04x | - |
1.0.1 | 10.1.7 | 8.6.x | 7.04x | MbgNMS 1.0.1 Release Notes |
1.1.0 | 10.2.0 | 8.6.x | 7.04x | MbgNMS 1.1.0 Release Notes |
1.1.1 | 10.2.0 | 8.6.x | 7.04x | MbgNMS 1.1.1 Release Notes |
1.2.0 | 10.2.0 | 8.x 10.x | 7.04x 7.06.x | MbgNMS 1.2.0 Release Notes |
1.2.1 | 10.2.0 | 8.x 10.x | 7.04x 7.06.x | MbgNMS 1.2.1 Release Notes |
1.2.2 | 10.2.0 | 8.x 10.x 16.x | 7.04x 7.06.x 7.08.x | MbgNMS 1.2.2 Release Notes |
1.2.3 | 10.2.0 | 8.x 10.x 16.x | 7.04x 7.06.x 7.08.x | MbgNMS 1.2.3 Release Notes |
mbgNMS security
Meinberg NMS or DataMiner? How to migrate?
As the Meinberg NMS is based on a standard DataMiner platform, both Meinberg and Skyline customers can benefit from this. You can start off with a Meinberg NMS and add third-party products to it, or you can transition a Meinberg NMS into a full DataMiner System. Moreover, existing DataMiner customers can always expand their system and add the "Meinberg Element Manager" to get everything the Meinberg NMS offers.
The overview below illustrates four basic migration scenarios.
Start with mbgNMS
- Out-of-the-box solution, based on DataMiner and sold by Meinberg
- Comes with fixes set of features and functionalities to manage, control, and monitor a Meinberg ecosystem (consolidated in the Meinberg Element Manager app.
- Allows expansion with third-party products, e.g. switches.
Transition into full DataMiner System & transition into Skyline customer
- True multi-vendor and fully customizable DataMiner System, sold by Skyline Communications
- Supports the Meinberg Element Manager app, Meinberg products, and any product from any vendor
Notes:
*1 Requires one license per non-modular Meinberg product, one license per modular Meinberg chassis, and one license per Meinberg modular card (IMS series). - HPS card: by default one DataMiner element is created per PTP instance, i.e. more than one license is required per card. This behavior can be turned off. - SyncMon card: SyncMon cards can optionally create a separate DataMiner element. If this feature is activated, each SycnMon card needs an element license. - Meinberg Element Manager, IDP elements: no element license required. |
*2 Mandatory. |
*3 Requires one license per third-party product instance. |
*4 Engineering services on top of mbgNMS, e.g. add visual or create an automation script. The Meinberg Element Manager app itself cannot be changed. |
*5 No need to order Meinberg connectors or Meinberg Element Manager; those will be transitioned to the DataMiner platform. |
*6 DataMiner IDP app needs to be purchased separately. Please reach out to your Skyline sales representative in case you already have IDP running on your system. Checks will be required to make sure the existing system will be compatible. --- *7 LANTIME connectors: * LANTIME Modular series requires SYSII-connector (includes all connectors to manage all supported LANTIME cards). * LANTIME Non-Modular requires DEVII-connector per Meinberg series (e.g. two connectors required to support M100 and M300, one connector required for M300 and M320) * Sync-Mon Node connector is included with the purchase of any LANTIME modular or non-modular connector * Connectors can be updated free of charge from LANTIME V8 to V10 API connector versions (requires active M&S agreement) |
Integration with DataMiner PTP
Are you using Meinberg clocks in a PTP ecosystem? Then take a look at the DataMiner PTP app.
Are you interested in customer examples? Check out our use case section.
More information about mbgNMS
Demo videos
Check out our series of short demonstration videos in our Dojo use case and video library:
- Main features of the Meinberg Network Management System (mbgNMS) - DataMiner Dojo (video)
- Meinberg NMS Dashboards Module - DataMiner Dojo (video)
- Meinberg NMS - Discovery and Provisioning (1/4) - DataMiner Dojo (video)
- Meinberg NMS - Monitoring and Control (2/4) - DataMiner Dojo (video)
- Meinberg NMS - Configuration Management (3/4) - DataMiner Dojo (video)
- Meinberg NMS - Firmware Management (4/4) - DataMiner Dojo (video)
- Meinberg Network Management System (mbgNMS) - DataMiner Dojo (use case)
Info sheets
Quick Info Sheet: mbgNMS: Meinberg Network Management System (meinbergglobal.com)
Data Sheet: mbg-nms-datasheet.pdf (meinbergglobal.com)
More Info: detailed information is also available on the Meinberg website.
Presentation
MbgNMS presentation
Manual
SLC_UM_Meinberg_NMS_REV010.pdf
Interested in a demo?
Feel free to reach out to Meinberg's or Skyline's sales team. We have demo systems available to show you everything about the Meinberg NMS and DataMiner.
