Hello,
I have these values for a discreet param defined in my protocol and they appear in a dropdown menu in my DMA. I want the same values to appear in a dropdown on my LCA. How should I make the query so it returns only these values.
In the meantime I found a solution by doing the following: I created a custom GQI data source, where i added the names and values for the discreet params and I used it in a query so they can appear in the dropdown.
It looks like this question has already been answered in the comments. To make it clear that this question no longer requires an answer, I have added this pro forma answer so that we can mark it as resolved.
Hi Emilija
You mentioned that you want to display the values inside a dropdown menu in an LCA. Should the discretes be displayed inside a Dropdown component, or do you prefer them to be shown the same way as in Cube, if so you can use the Parameter Page component?
Kind regards
