Dshboard with monitor values of a spectrum
1.18K views19th June 2026
Tim Eysermans252 18th June 2026 0 Comments
I have a script that goes through a large number of measurement points of a spectrum. See pictureafter which a monitor is created with the values. I would now like to display these values in a dashboard. Does anyone know how I can do this?
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 19th June 2026
Wout Mahieu [SLC] [DevOps Catalyst]12.47K Posted 18th June 2026 0 Comments
Hi Tim,
If you want to display this exact data page in a Dashboard, you can use the Parameter Page component. You just need to add the component and the parameter page itself as data.
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 18th June 2026
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 19th June 2026 0 Comments
Hi Tim,
When you define parameters for your monitors, they are exposed in Cube as single parameters (as shown in your screenshot).
To cover your use case, retrieving parameters across multiple monitors and spectrum elements would require, I believe the best approach is creating an ad-hoc data source that collects these metrics so it can be displayed in a table. From there, you can perform the required aggregation.
Hope it helps.
Tim Eysermans252 Posted 19th June 2026 0 Comments
It works for 1 element, I want to do it for this protocol. So I can count for example all: CN High, CN Low. Is it possible
Tim Eysermans Answered question 19th June 2026
Tim Eysermans252 Posted 18th June 2026 1 Comment
Hello, I want make a querie so I get all the monitor points of all elements (spectrums), with a filter "CN high band*". Is this posible
Tim Eysermans Posted new comment 26th October 2026
Tim Eysermans commented 26th October 2026
is solved
