Can I use dataminer for PTP monitoring? if yes, how it is helpful?
Solved4.19K views27th January 2023broadcast PTP
pramod Gupta [SLC] [DevOps Member]277 5th August 2020 0 Comments
Is it possible to trace the PTP using dataminer? If yes, is there any recommendation of specific PTP generators? What kind of PTP generators are already integrated with dataminer, if any?
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 27th January 2023
Thomas Gunkel [SLC] [DevOps Enabler]1.24K Posted 6th August 2020 1 Comment
Hi Pramod,
Please find below the products that are currently supported. As Ben stated, any other PTP node can be added at any time.
  • PTP grandmaster clocks
    • Tektronix SPG8000
    • Meinberg Lantime M3000
    • Evertz 5700MSC
  • PTP boundary/transparent clocks
    • Cisco Nexus 9000 series
    • Arista 7000 series
  • PTP analyzers
    • Tektronix Prism
  • PTP slave clocks
    • Imagine SNP
    • Lawo Nova HD Core
    • Lawo Powercore
    • Ross Newt
pramod Gupta [SLC] [DevOps Member] Posted new comment 8th September 2020
pramod Gupta [SLC] [DevOps Member] commented 8th September 2020
Thanks Thomas, it really helps.
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 5th August 2020 0 Comments
Hi Pramod,
You can surely use DataMiner to monitor and manage PTP across your network.
Please have a look at this blog post for more information.
Ive Herreman [SLC] [DevOps Enabler] Answered question 5th August 2020
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K Posted 5th August 2020 0 Comments
Also in the DataMiner Help files there are further details on the PTP App. If you want to sit back and relax, dataminer.tv also provides some interesting presentations and demos.
Thomas Gunkel is our expert on this specific domain, so it might be worth touching base with him as well.  There are a number of third-party products supported out of the box by the PTP Solution, but we can integrate any new ones as well.
Marieke Goethals [SLC] [DevOps Catalyst] Edited answer 18th August 2020
Jens Vandewalle [SLC] [DevOps Advocate]10.08K Posted 27th January 2023 0 Comments
Hi Pramod,
Today we have a PTP demo available in the public section of Ziine.
