How to set Bus Address from Automation script c#
Solved2.17K views18th July 2023automation scipt
Niraj Deval42 26th April 2021 2 Comments
Miguel Obregon [SLC] [DevOps Catalyst] commented 26th April 2021
Hi Niraj, please could you elaborate a bit more your question? Are you planning to modify the bus address for an element?
Can you provide us more information about your use case?
Niraj Deval commented 26th April 2021
Yes, i would like to modify bus address for an element that is already created. bus address in TCP/IP settings
Thijs Vanovenacker [SLC] [DevOps Advocate]2.54K Posted 30th April 2021 0 Comments
Hi Niraj,
If you use DIS to develop your scripts, you can make use of the Class Library features.
A nice introduction video is available for you to learn how to use the Class Library in an automation script: DataMiner Integration Studio (DIS) Class Library – DataMiner Dojo
In following feature highlights you can find some examples on updating elements:
Class Library 1.2.0.5: New feature highlights - DataMiner Dojo
For you it will be a matter of updating the DeviceAddress property on the connection object.
once you updated this property you just call the Update() method on the element object to apply the changes and done!
See example I created below:
I hope this helps you out. Please let us know in case of any problems/questions. 😉
