How to secure communication between DataMiner agents
Solved3.74K views14th October 2020DMS encryption security SLNet SSL-TLS
9
Miguel Barquet [SLC] [DevOps Advocate]2.00K 14th October 2020 0 Comments
More and more we are seeing large clusters that extend across large geographical areas. DataMiner agents need to synchronize with other agents in distant points. In those cases, the communication traffic may traverse multiple routers, firewalls and in some cases even cross the public internet.
I would like to know what security measures are in place by default to secure SLNet communication between DataMiner agents that belong to the same DMS. What are the native capabilities DataMiner has available to encrypt the communication between agents? What are the recommended practices and configurations?
If possible, share links to those materials that explain how to set up secure communication between agents, if not done by default.
Thanks
Miguel Barquet [SLC] [DevOps Advocate] Selected answer as best 14th October 2020
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 14th October 2020 1 Comment
All SLNet communication of a DataMiner Agent can be configured to use encrypted connections. Data sent over those connections will be encrypted with a Rijndael algorithm, using a 256-bit session key (negotiated during authentication via a 1024 bit RSA key pair).
Details on how to configure this can be found in the DataMiner help (link).
Gellynck Jens [SLC] commented 14th October 2020
Note this setting will be enabled by default starting from 10.0.13
Karel Lodefier [SLC] [DevOps Member]724 Posted 14th October 2020 0 Comments
Also referring to following question:
https://community.dataminer.services/question/communication-dma-to-dma-or-dma-to-dataminer-client/
Karel Lodefier [SLC] [DevOps Member] Answered question 14th October 2020
Gellynck Jens [SLC]2.72K Posted 14th October 2020 0 Comments
Since 10.0.11.0 it’s also possible to configure TLS encryption between the Elastic nodes of the DMS (only for new Elastic installations)
Gellynck Jens [SLC] Answered question 14th October 2020
