Credentials Management for Dataminer Automation Script Solution
Solved2.83K views30th September 2024
Ramesh Rajasekaran [DevOps Advocate]978 10th July 2024 4 Comments
Currently, I am storing the credentials in an XML file and consuming them in the code. But I don’t want to store the credentials in XML due to security reasons.
Is it possible to store the credentials in the Windows credentials store and fetch them in code? Is it possible to access the Windows credentials store from a data miner?
Also, please suggest if there are any other better options to store and fetch the credentials to improve security.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Ramesh Rajasekaran [DevOps Advocate] commented 10th July 2024
I am using dataminer automation scripting solution
Rebecca Kelsall [DevOps Advocate] commented 10th July 2024
I am not sure using Windows Credentials is a good option because it would rely on that server available or for it to be configured on the entire cluster. Does anyone know of a secure way to save them within Dataminer, either by a configurable hidden parameter in the XML or are people building a driver to encrypt and to store them?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2024
Hi Ramesh,
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
As this question has now been inactive for a long time, I will close it. If you still want more information about this, could you post a new question?
Flávio Jacinto [SLC] [DevOps Advocate]898 Posted 12th July 2024 0 Comments
Hi Ramesh,
I’d like to inform that we’re further looking into expanding the existing DataMiner credentials library to incorporate support for Automation Scripts.
Kind Regards,
Jon Corral [SLC] [DevOps Member]464 Posted 10th July 2024 0 Comments
Hello Ramesh,
Some weeks ago I posted a similar question in Dojo. In my case, I wanted to move the credentials from the code to somewhere safer and providing better privacy. The answer I got could help you. As far as I know, there is no way right now of storing them in Dataminer.
AdHocDataSource – UI or option to pass some input parameters that are hardcoded and sensible – DataMiner Dojo
Jon Corral [SLC] [DevOps Member] Answered question 10th July 2024
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 11th July 2024 0 Comments
Hi Ramesh,
If using an external service is possible for your configuration, you could also consider using a service like the Azure Key Vault, Keys are stored in the Azure cloud, and there is an easy to use API and nuget (Azure.Security.KeyVault.Secrets) that allows you to retrieve the credentials from C# code.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 11th July 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 10th July 2024 0 Comments
Hi Ramesh,
As mentioned by Jon, currently there is no mechanism to store credentials in DataMiner. There are already a feature suggestion that covers your use case:
Option to link a credential library to an automation script
Regards,
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 10th July 2024
