CassandraCluster System Checks
Solved2.14K views7th May 2024
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 5th April 2024 1 Comment
I’ve set up a CassandraCluster element and noticed the System Checks were throwing some warnings.
I’ve looked into two of them already:
  • Authorizer:  I’ve set it to CassandraAuthorizer in the yaml file and restarted the Cassandra service on all 3 nodes
  • Unknown seed:  I corrected a typo in the seeds of one of the nodes and restarted the Cassandra service on that node
I’ve triggered the Run System Checks button on the element, but I don’t see the status of these tests change.
I’ve also already tried an element restart.
How do I make sure it sees the corrections?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th May 2024
Jeroen Geldhof [SLC] [DevOps Enabler] commented 8th April 2024
I restarted all 3 nodes, and then it worked.
Michiel Saelen [SLC] [DevOps Advocate]6.56K Posted 19th April 2024 0 Comments
Hi Jeroen,
As restarting the Cassandra service fixed the problem, it is most likely because the Cassandra service was not restarted after making changes to the ‘/etc/cassandra/cassandra.yaml’ configuration file. Only on startup of the Cassandra service, the configuration files will be read. So any changes to the files will only be applied after a service restart.
Jaime Leal [SLC] [DevOps Member]668 Posted 5th April 2024 0 Comments
HI Jeroen
Maybe you can try setting another IP address of one of your nodes on the connection setting page to see if that refreshes the connection and shows the changes.
Jaime Leal [SLC] [DevOps Member] Answered question 5th April 2024
