What port needs to be open to connect DIS to a DMA
Solved1.19K views8th December 2023DataMiner Integration Studio Ports
Miguel Barquet [SLC] [DevOps Advocate]1.92K 8th December 2023 0 Comments
I am reviewing our documentation, but I am unsure which port to open in order to connect DIS to a DMA.
Configuring the IP network ports | DataMiner Docs
Please advise.
Miguel Barquet [SLC] [DevOps Advocate] Selected answer as best 8th December 2023
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 8th December 2023 2 Comments
Hi Miguel,
Based on this topic it seems TCP port 8004 should suffice.
Tom Waterbley [SLC] [DevOps Enabler] commented 8th December 2023
Indeed, DIS uses the same SLNet connection as for example Cube.
Bert Buysschaert [SLC] [DevOps Advocate] commented 8th December 2023
This would still require either port 80 or 443 to be accessible to retrieve the ConnectionSettings.txt for autodetection and EndPoints.txt if a custom port would be configured.
Moving forward, it is recommended in general to open port 443 so that gRPC can be used (which will become the default, and only requires 443).
