What happens when I pause my element?
Solved3.37K views8th September 2020elements
Michiel Saelen [SLC] [DevOps Advocate]6.50K 8th September 2020 0 Comments
To be able to access the trend information while the device is no longer being polled we put the element to a paused state.
When an element is paused will it drop all the connections between the DMA and the device or will it only pause the communication?
Michiel Saelen [SLC] [DevOps Advocate] Selected answer as best 8th September 2020
Jan Vanhove [SLC] [DevOps Member]1.23K Posted 8th September 2020 0 Comments
Michiel, when an element gets paused no actions are done on the open connections.  This means that if the connection was open, it will remain open.  Note that when an element is in paused state after a DataMiner restart, it does not mean the connection will be initiated, because typically this gets done when a first command is sent.
