Visual Overview – Element name from element ID
Solved1.50K views18th July 2023Visual Overview
Ailton Luz [SLC] [DevOps Member]51 13th July 2021 0 Comments
Having the element ID how do I get the element name? Element ID is in a parameter, and I want to execute a script with the element name as an input.
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 13th July 2021 1 Comment
There is no Visual Overview functionality that will make the ID to name translation for you. Typically IDs are provided as an input to a script. In there, you can easily request additional information of the element using its ID.
Note that you can access the element name of a page or shape using the [this element] placeholder, see help.
Ailton Luz [SLC] [DevOps Member] commented 13th July 2021
Thanks, Sebastiaan. I decided to go for a workaround and add a second parameter in the driver with the element name.
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 14th July 2021 1 Comment
Another way is to adapt your script and make a method that figures out if name or ID is used
    private static IDmsElement GetElement(IDms dms, string elementInfo)
if (elementInfo.Contains(“/”))
DmsElementId dmsElementId = new DmsElementId(elementInfo);
if (dms.ElementExists(dmsElementId))
return dms.GetElement(dmsElementId);
else
throw new ElementNotFoundException(dmsElementId);
else
if (dms.ElementExists(elementInfo))
return dms.GetElement(elementInfo);
else
throw new ElementNotFoundException($”No element found with name ‘{elementInfo}'”);
Ailton Luz [SLC] [DevOps Member] Posted new comment 14th July 2021
Ailton Luz [SLC] [DevOps Member] commented 14th July 2021
Hi Jens, in this scenario I can’t change the script.
