Visual Overview – Best way to show alarm on connection
Solved1.97K views18th July 2023Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 8th October 2021 0 Comments
I have a connection from one function to another one by just drawing a line. By default the connection line is gray and it should only show an alarm when there is something wrong with the signal.
Currently I achieve this by duplicating my line and show a red line when there is something wrong. In the other case I show the gray line.
My question is there are other ways to achieve this without having to duplicate my lines.
Jarno Lernou [SLC] [DevOps Enabler]6.09K Posted 8th October 2021 0 Comments
Hi Jens, is it an option to use conditional monitoring (ref. DM Help)? If you link the connection line to a specific parameter, then it will only be colored whenever the alarm condition is fulfilled.
In case, the connection line is linked to the interfaces by making use of the ShowInterfaceAlarmColor option (ref. DM Help), then you can add the condition as well to the linked parameters.
In case this won't work then you can indeed use the new feature proposed by Toon.
