View Element Property In Visio
Solved1.82K views2nd November 2021Element Property ShapeData Visio
Leynard Puri 29th October 2021 0 Comments
Hi all,
How can I add element property to show in a shapedata?
Thanks!
Bert Vandenberghe [SLC] [DevOps Enabler] Selected answer as best 2nd November 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.68K Posted 29th October 2021 4 Comments
Hi Leynard,
You will need to add a reference to the view, element or service where the property is located. For example, if you would like to display a property assigned to an element, you could proceed as follows:
Element: TEST_ELEMENT
Property: BatteryType
More information in DataMiner Help
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 29th October 2021
Also note that you need to add a ‘*’ in your shape text.
Bert Vandenberghe [SLC] [DevOps Enabler] commented 29th October 2021
PS: don’t forget the space between battery and type.
Michiel Vanthuyne [SLC] [DevOps Advocate] commented 29th October 2021
For more information on all possibilities and configurations of visual overview, you can follow the excellent visual overview course here https://community.dataminer.services/courses/visio/
Leynard Puri commented 2nd November 2021
Thanks Team! I was able to show the property in the Visio shape data!
