SRM – Profile Load Script – How to get an element from a resource?
Solved2.47K views9th September 2021profile load script SRM SRM resources
Bruno Dias [SLC] [DevOps Member]2.37K 9th September 2021 0 Comments
Hey everyone,
I’m developing a ProfileLoadScript for a SRM solution.
There are some actions that I need to perform in the element that generates the resource (because not all the parameters are exported to the function DVE). What’s the best way to get an element reference based in a Resource ID?
Bruno Dias [SLC] [DevOps Member] Selected answer as best 9th September 2021
Pedro Almeida [SLC]296 Posted 9th September 2021 0 Comments
Dear Bruno,
If you are using Function Resources and not “normal” resources, you can cast it to a FunctionResource and in there, you have the Main DVE DMA Id and Main DVE Element Id. Having both, you can use FindElement on the engine with those parameters and do the logic you need.
Emmanuel Dal [SLC] [DevOps Member]4.63K Posted 9th September 2021 2 Comments
Hi Bruno,
A profile-load script is supposed to apply a profile on a function DVE, nothing more.
If possible, I’d suggest to extend the function definition so that the missing parameter is part of the function.  Is that an option ?
Emmanuel Dal [SLC] [DevOps Member] Posted new comment 9th September 2021
Bruno Dias [SLC] [DevOps Member] commented 9th September 2021
Yes, it’s an option.
This is for a router function. Goal was to create a resource per input and per output, so we were not including the Matrix parameter with all inputs and outputs to the resource DVE.
However, to execute the ConnectMatrixCrosspoint call, we need an element reference (that includes the Matrix), not the resource. So, indeed adding the Matrix parameter to the resource would solve, but not sure if that’s coherent.
Emmanuel Dal [SLC] [DevOps Member] commented 9th September 2021
Based on the use case you’re indicating, retrieving the main Element seems to be the correct approach.
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 9th September 2021 0 Comments
Hi Bruno,
With below code you have the element info independent if you’re working with Function Resources or Virtual Function Resources
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 9th September 2021
