Spectrum thumnails displaying round robin monitor points
Solved2.65K views11th July 2023spectrum analyzer Visio
Bernard Pichot [SLC] [DevOps Advocate]1.32K 18th January 2021 0 Comments
In order to display a spectrum thumbnail in Visio you should specify the following parameters
ParameterID|MonitorRef|ScriptVariable|MeasurementPointID|PresetName|SpectrumOptions
When the spectrum analyser is doing a round robin between several measurement points, what should be the syntax to refresh the visio thumbnail every time a new measurement point trace is available and then follow the round robin ?
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 20th January 2021 0 Comments
Hi Bernard, as Wouter and Miguel already indicated, this is not possible, and probably also not very useful as all 5 traces will be taken with short intervals, and then you will see always the same last trace until the next time the monitor runs.
However, you can probably provide a solution by making the MeasurementPointID reference dynamic and linking it to a session variable. If you also add buttons for the 5 measurement points setting this session variable, a user can choose for which measurement point he/she wants to see the last trace.
Wouter Demuynck [SLC] [DevOps Advocate]6.75K Posted 19th January 2021 1 Comment
As far as I remember, this is not possible. The thumbnail always links to one trace result for one specific measurement point used by a monitor.
I don’t think it would be very useful either, as for a monitor running once an hour and measuring a trace on 5 measurement points, you would see the 5 traces passing by around the hour and then see the same trace (last one measured) for the remainder of the hour.
Bernard Pichot [SLC] [DevOps Advocate] Posted new comment 19th January 2021
Bernard Pichot [SLC] [DevOps Advocate] commented 19th January 2021
Thanks Wouter,
in my use case the trace is updated every ~5 seconds that’s why it can make sense see the latest trace
Miguel Obregon [SLC] [DevOps Catalyst]22.39K Posted 18th January 2021 2 Comments
Hi Bernard,
When you configure the monitor, you define how often the trace will be updated:
In the monitor you can define the script and the measurement point that will be used to update the trace.
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 19th January 2021
Bernard Pichot [SLC] [DevOps Advocate] commented 18th January 2021
Thanks Miguel,
But during the round robin, the measurement point is changing continously so is there a way to specify that the visio should display the latest available trace whatever the measurement point/preset used ?
Miguel Obregon [SLC] [DevOps Catalyst] commented 19th January 2021
Hi Bernard, as far as I know this is not possible. The Visio shape was implemented to visualize a specific trace
