Spectrum Element | Automation Set Parameter
Solved1.51K views30th September 2024automation engine spectrum analyzer spectrum data
Yohan Silva [DevOps Enabler]404 11th June 2024 3 Comments
Hello dojo,
I am facing an issue with spectrums: When we try to set the center frequency by an automation it fails beacuse it cannot “verify” if the set command was correctly set, but it works when we make it manually. There is any way to solve it?
Kind regards,
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 12th June 2024
Hi Yohan,
Are you using the spectrum preset class to set the center frequency?
https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Automation.SpectrumPreset.html
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th August 2024
Hi Yohan,
Do you still need help with this? If yes, could you provide some more information, as requested by Miguel and Wouter? Or if not, could you select the answer (using the ✓ icon) to indicate that the question is resolved?
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
As this question has now been inactive for a long time, I will close it. If you still want more information about this, could you post a new question?
Wouter Demuynck [SLC] [DevOps Advocate]7.08K Posted 12th June 2024 0 Comments
Hi Yohan,
Do be aware that for spectrum elements there is an extra layer in between the protocol and clients. This layer maintains multiple active sessions, each with their own settings for parameters like center frequency. DataMiner then cycles through this sessions, measuring traces for the different clients. This allows multiple clients each using different settings to use the spectrum device simultaneously.
It’s not recommended to directly set these parameter values.
Is there a specific use case you want to achieve? For running background actions on spectrum elements, spectrum scripts and monitors are probably the way to go.
