Router connection with dataminer
Solved1.18K views18th April 2025
Davor Joleski [DevOps Enabler]743 15th October 2024 3 Comments
Hi guys i want to ask you what is the ways step by step to connect with router to take the data and connect with dataminer and work with those data
is it possible to have obstacles for DMA some overflow after fetching data
Miguel Obregon [SLC] [DevOps Catalyst] commented 16th October 2024
Hi Davor,
Please could you elaborate a bit your use case? Is there already an element monitoring the router? If so, what information are you expecting to retrieve?
Thanks,
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th January 2025
Hi Davor,
I see that this question has been inactive for some time. Do you still need more information for this? If not, could you select Miguel's answer to indicate that the question is resolved?
Miguel Obregon [SLC] [DevOps Catalyst]22.03K Posted 17th October 2024 2 Comments
Hi Davor,
I would suggest to follow the following courses:
  • DataMiner Foundational (DataMiner Fundamentals and DataMiner Configurator)
  • Data Acquisition Control Plane (DataMiner Connector Integration: SNMP Basics)
Hope it helps.
Davor Joleski [DevOps Enabler] commented 17th October 2024
yeah that case is okej but first how to take the data any risk of information can take do i need to take some connector from catalog or just to implement in my connector
Baptiste Pattyn [SLC] [DevOps Advocate] commented 17th October 2024
Hi Davor, you can always look for existing connectors on the catalog (https://catalog.dataminer.services). You can search on model or vendor.
Davor Joleski [DevOps Enabler]743 Posted 16th October 2024 0 Comments
Hi Miguel ,no we still on the beginning, we trying first to connect to snmp what kind of data doesn’t matter we need first the steps to connect with router how to connect with snmp and after that ,how to connect with dataminer,is it way to have obstacles to overflow the Dataminer agent after fetching data from start to the end i need ways
Davor Joleski [DevOps Enabler] Answered question 16th October 2024
