Restrict port range for comms from DMS to cube
Solved2.52K views18th July 2023Cube Desktop App DataMiner Cube port VLAN
Chris Glover [DevOps Advocate]2.17K 17th August 2021 0 Comments
Is it possible to specify a port range for the comms from the DMA to Cube? e.g. restrict it so it can only use ports in the range 10000-20000?
To make our Infosec guys happy, they'd want a limited port range instead of having it wide open, as we have some instances of Cube that are not in the same VLAN as the DMA.
Thanks
Chris
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 17th August 2021 0 Comments
Hi Chris,
There is a similar question in Dojo about this topic:
.NET Remoting with eventing port
It’s not possible to specify the port range to be used for eventing.
This is a limitation of the .net framework.
As indicated by Wale, a possible workaround could be using polling instead of eventing.
