Passing Element Name from Visio to LCA for Automation Script Input
Solved1.19K views26th March 2025LCA Low Code App Feeds URL Visio
Ana Pinho [SLC] [DevOps Member]1.42K 26th March 2025 0 Comments
Hey dojo,
I have a Visio diagram on an element that includes a button to launch an LCA.
When linking the Visio to the LCA, I pass the element name in the URL, as it will be needed later.
Within the LCA, when a button triggers an automation script, the script must use the element name from the URL as an input parameter.
Like this:
The URL is something like this:
The yellow part is working, it's selecting a element on a dropdown, but the green that is used for the button, is not able to do the link.
When the final script is executed, I'm logging the input parameter and it's empty.
Any clue what I'm doing wrong?
Thank you
Ana Pinho [SLC] [DevOps Member] Selected answer as best 26th March 2025
Robin Debel [SLC] [DevOps Enabler]2.36K Posted 26th March 2025 2 Comments
Hi Ana,
The syntax you are currently using to pass the string value is the syntax used to 'feed' a value to a certain component. In the action however you are using the URL Query Param. The documentation for how the text value should be passed can be found here.
Kind regards,
Robin
Ana Pinho [SLC] [DevOps Member] Posted new comment 26th March 2025
Wout Mahieu [SLC] [DevOps Catalyst] commented 26th March 2025
An example with the correct syntax when using URL data:
&data={"feed":{"strings": ["YOUR STRING VALUE"]}}
Also a small note here, in 10.5.4 there is an issue where this will not work correctly for 'On open' events.
Ana Pinho [SLC] [DevOps Member] commented 26th March 2025
problem solved 🙂 Thank you!
