Meinberg Network Management System setup
Solved2.78K views17th July 2023meinberg
Lars von Oertzen [SLC] [DevOps Advocate]371 20th December 2021 1 Comment
Hey!
We are currently setting up a Meinberg Network Management System and the license is activated already.
Looking at the manual, we come to point 1.1.2, where you install the Meinberg Element app package.
This package is installed, like previous packages, but in point 7 you must run Meinberg_SetupWizard. It refuses to do so, and we get the error message as written below.
Software versions:
– main version patch 10.1.0.0-11132
– Meinberg element manager app 1.0-RC02-20210831045500.
Any idea how to get around this error and successfully complete the setup of the Meinberg Network Management System?
There are also some alarms visible in DataMiner but this may be caused due to the wizard not being able to run:
Examples for errors of the setup wizard:
Script Failure (Meinberg_SetupWizard): (after retries) (Code: 0x80040251) Skyline.DataMiner.Net.Exceptions.DataMinerException: No Assembly found for cookie 8
(62,52): error CS0234: The type or namespace name ‘InteractiveAutomationToolkit’ does not exist in the namespace ‘Skyline.DataMiner.DeveloperCommunityLibrary’ (are you missing an assembly reference?)
(721,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(781,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(944,52): error CS0234: The type or namespace name ‘InteractiveAutomationToolkit’ does not exist in the namespace ‘Skyline.DataMiner.DeveloperCommunityLibrary’ (are you missing an assembly reference?)
(945,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(946,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(1071,52): error CS0234: The type or namespace name ‘InteractiveAutomationToolkit’ does not exist in the namespace ‘Skyline.DataMiner.DeveloperCommunityLibrary’ (are you missing an assembly reference?)
(139,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(140,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(885,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(918,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(259,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(260,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(1138,52): error CS0234: The type or namespace name ‘InteractiveAutomationToolkit’ does not exist in the namespace ‘Skyline.DataMiner.DeveloperCommunityLibrary’ (are you missing an assembly reference?)
(1139,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(1140,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(2419,52): error CS0234: The type or namespace name ‘InteractiveAutomationToolkit’ does not exist in the namespace ‘Skyline.DataMiner.DeveloperCommunityLibrary’ (are you missing an assembly reference?)
(296,26): error CS0234: The type or namespace name ‘CommunityLibrary’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(298,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(299,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(300,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(2488,26): error CS0234: The type or namespace name ‘CommunityLibrary’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(2490,52): error CS0234: The type or namespace name ‘InteractiveAutomationToolkit’ does not exist in the namespace ‘Skyline.DataMiner.DeveloperCommunityLibrary’ (are you missing an assembly reference?)
(2491,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(2492,26): error CS0234: The type or namespace name ‘Library’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
(2620,52): error CS0234: The type or namespace name ‘InteractiveAutomationToolkit’ does not exist in the namespace ‘Skyline.DataMiner.DeveloperCommunityLibrary’ (are you missing an assembly reference?)
(891,43): error CS0246: The type or namespace name ‘IDmsProtocol’ could not be found (are you missing a using directive or an assembly reference?)
(924,39): error CS0246: The type or namespace name ‘IDmsView’ could not be found (are you missing a using directive or an assembly reference?)
(146,29): error CS0246: The type or namespace name ‘IDms’ could not be found (are you missing a using directive or an assembly reference?)
(151,40): error CS0246: The type or namespace name ‘IDms’ could not be found (are you missing a using directive or an assembly reference?)
(151,17): error CS0246: The type or namespace name ‘IDmsElement’ could not be found (are you missing a using directive or an assembly reference?)
(787,38): error CS0246: The type or namespace name ‘IDms’ could not be found (are you missing a using directive or an assembly reference?)
(802,39): error CS0246: The type or namespace name ‘IDms’ could not be found (are you missing a using directive or an assembly reference?)
(217,31): error CS0246: The type or namespace name ‘IDmsElement’ could not be found (are you missing a using directive or an assembly reference?)
(228,43): error CS0246: The type or namespace name ‘IDmsElement’ could not be found (are you missing a using directive or an assembly reference?)
(233,43): error CS0246: The type or namespace name ‘IDmsElement’ could not be found (are you missing a using directive or an assembly reference?)
Thomas Gunkel [SLC] [DevOps Enabler] commented 20th December 2021
mbgNMS requires a minimum DataMiner version which is DataMiner release 10.1.9. Your system needs to be updated first before you can run the wizard.
More details can be found on the Meinberg partner page on Dojo: https://community.dataminer.services/partner/meinberg/.
Also have a look at the Meinberg manual where you can find detailed instructions how to install and operate mbgNMS: https://community.dataminer.services/download/slc_um_meinberg_nms_rev000-pdf-2/ > chapter 1.1.2 “Running the Main Installer”
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.61K Posted 20th December 2021 0 Comments
The notices in the alarm console are because the Ticket Manager and Service Manager are licensed on the agent, but no Elastic database is configured. Both these modules require an Elastic database. These notices are not linked to (or caused by) the setup wizard of the mbgNMS.
Like Thomas mentions in his comment, you need to have at least 10.1.9 to install mbgNMS.
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 20th December 2021 0 Comments
It looks like the Meinberg_SetupWizard script is using functionality from the DIS Class Library and also from the InteractiveAutomationToolkit community class library package.
The error you are receiving seems to be because the shared code it’s trying to use cannot be found. This is probably because the script was not compiled with all shared code included. You could check this by clicking the “Validate” button at the bottom of the C# action in the script: I’ll check with the squad working on this solution if there could be an issue with the script in the package.
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 20th December 2021
