Low Code Apps – logging (best practice)
Solved2.73K views5th July 2023logging low code apps
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 12th June 2023 0 Comments
I'm building some Low Code Apps and need a way to log information for debugging purposes, providing additional information, etc.
Not sure if there already something that I can reuse? If not, I'm eager to build something myself, but I'm looking for some best practices input since I can think of a few approaches to make this available:
  • store logging in logger tables (make use of aliases for each application)
  • store the data in separate files (like done for the SRM framework)
  • make the data for each application individually available in DOM
  • create 1 DOM module for logging purposes
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 5th July 2023 0 Comments
Hey Jens,
The best approach really depends on what exactly you want to log. However, in most cases, I personally recommend using logger tables. This helps avoid problems related to files and synchronization. Although using DOM is an option, I think it may be excessive if you're only interested in basic logging.
