Low Code Apps – logging (best practice)
Solved2.51K views5th July 2023logging low code apps
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 12th June 2023 0 Comments
I’m building some Low Code Apps and need a way to log information for debugging purposes, providing additional information, etc.
Not sure if there already something that I can reuse? If not, I’m eager to build something myself, but I’m looking for some best practices input since I can think of a few approaches to make this available:
  • store logging in logger tables (make use of aliases for each application)
  • store the data in separate files (like done for the SRM framework)
  • make the data for each application individually available in DOM
  • create 1 DOM module for logging purposes
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 5th July 2023 0 Comments
Hey Jens,
The best approach really depends on what exactly you want to log. However, in most cases, I personally recommend using logger tables. This helps avoid problems related to files and synchronization. Although using DOM is an option, I think it may be excessive if you’re only interested in basic logging.
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 12th June 2023 1 Comment
Hi Jens, this is not full logging, but it can help for debugging custom GQI connectors.
If you try/catch the errors in your code, you can throw a “GenIfException”. This will then be visualized in the app visualization, e.g. a table. It’s not very clean to use this in production code as the errors will be visible to the user, but it can help while debugging.
try
//some code to retrieve or process data goes here
catch (Exception e)
throw new GenIfException($”failed to fetch/process data from source: {e}”);
Jens Vandewalle [SLC] [DevOps Advocate] Posted new comment 13th June 2023
Jens Vandewalle [SLC] [DevOps Advocate] commented 13th June 2023
Hi Michiel, I’m more looking for a way to store this error logging so that someone can have a look later. I can always show it by using an IAS, but if the user forgets to make a capture of it the logging is lost.
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 12th June 2023 0 Comments
Jens,
What is done in SRM has few drawbacks, due to the fact that it requires a shared folder accessible from all DMAs of a cluster.
There is also a LogHelper API available (RN26434) ; however there is no UI to visualize log records. You could of course implement an ad-hoc data source to retrieve them.
Emmanuel Dal [SLC] [DevOps Member] Answered question 12th June 2023
