Low Code App launch Script Not working
Solved2.33K views5th July 2023launch script low code apps
john watt94 13th May 2023 5 Comments
Following the training videos, I am trying launch a script from a low code app.  I create buttons I can click on but no script gets executed. In this screen shot I am simply attempting to launch a script called SetPropertyFromParameter2 with a single parameter.  Nothing happens.  The script is not actually executed.  I have tried this with all sorts of configurations.  This simple script simply writes a log of the passed value.  The script is not executed.  I cannot get a Low Code app to launch any automation script.  Am I missing some configuration?
Ive Herreman [SLC] [DevOps Enabler] commented 15th May 2023
Hi John,
Have you tested the button after you published the app?
They will not work while you are still in edit mode.
john watt commented 15th May 2023
Unfortunately I have
Which version of DataMiner are you running?
Version 10.3
I upgraded to 10.3.5 and it now seems to work
Jason Pitteman [SLC] [DevOps Member]556 Posted 17th May 2023 0 Comments
Hi John,
The feature launch automation script has been released in 10.3.3.
Kind regards,
