How to identify the cause of an error token in Process Automation
Solved1.80K views7th July 2023process automation
6
Ive Herreman [SLC] [DevOps Enabler]14.78K 10th January 2023 3 Comments
Hi Community,
In my Process Automation setup I get some stuck error tokens from time to time.
How can I identify why a token transitioned into an error state?
Edith Lansens [SLC] [DevOps Member] Selected answer as best 7th July 2023
Emmanuel Dal [SLC] [DevOps Member] commented 10th January 2023
Hi Ive,
For each token pushed into a process, a log file gets generated ( see https://docs.dataminer.services/user-guide/Standard_Apps/PA/Advanced_Configuration/PA_Logging.html)
The Element log files of the associated Queue Elements could also give valuable information.
In case they do not contain any useful information, please create a task so that we can further investigate.
Ive Herreman [SLC] [DevOps Enabler] commented 10th January 2023
Hi Emmanuel,
Thanks for your response.
I’ll reach out to you directly, as neither log file contains any indication as to why the tokens are flagged as failed.
Jeroen Geldhof [SLC] [DevOps Enabler] commented 10th January 2023
Hi Emmanuel and Ive.
Since I’m also starting to use PA, I’ve also been thinking about error handling.
I’ve created an error state and I also created an error message field in the DOM definition, which I intend the error handling to fill in the error message if something goes wrong.
Does this seem like a good way of working?
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 7th July 2023 0 Comments
As this question has been inactive for a long time, and it doesn’t look like an answer is still needed, I have added this pro forma answer so that we can mark it as resolved.
