How to export GQI results to an external system?
Solved2.58K views8th August 2023API call GQI
Edson Alfaro [SLC] [DevOps Advocate]1.77K 26th July 2023 0 Comments
Hi all,
Is it possible to export que query results to an external system?
I know we have use cases for Grafana and Power-BI, but they use specific connectors.
In this one, the end user is looking for some API call or any other way where they can get the results from a DataMiner query into their in-house system, either automatically or per on-demand request.
Thanks.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 8th August 2023
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 27th July 2023 0 Comments
Hi Edson,
Another possible option (similar to the one described by Ronald) could be using the DataAggregator and User Definable API.
The DataAggregator will export the query result to a CSV file. Then, you could use User Definable API to parse the result of the CSV file and expose it to the external system. The only problem I see here is how to trigger the DataAggregator on demand. The DataAggregator exposes a small API to trigger manually a job but I didn't test it so far.
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 27th July 2023
