How to display the resources and its columns using GQI – low code app
Solved1.45K views30th September 2024GQI custom operator GQI Data Source low code app
Baranisudha Murugesan [DevOps Member]1.16K 12th July 2024 5 Comments
Im creating a low-code app to display all my resources under my view->services from dataminer. I have retrieved serviceParam data from DMS, but facing difficulty with displaying the data in rows. I have referred this documentation – Modifying links to DataMiner objects | DataMiner Docs
but it doesn’t fit my requirements.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Steve Purcell [SLC] [DevOps Advocate] commented 12th July 2024
Hi Baranisurdha, Not sure if exactly what you are looking for, there is an example on our Ziine Dashboard which may fit your needs if you would like to take a look and review the GQI queries used. https://ziine.skyline.be/dashboard/#/
Then under Staging Area|SPU|OTT Summary
Ronald Gerard [SLC] [DevOps Enabler] commented 16th July 2024
Hi Baranisudha, in case you’re still stuck, could you elaborate a bit more what you are having trouble with exactly?
I’m assuming you are using an Ad Hoc data source of some sort to retrieve service parameters?
There are also similar data sources on GitHub that may be an inspiration:
https://github.com/topics/dataminer-gqi-data-source
Baranisudha Murugesan [DevOps Member] commented 16th July 2024
I have element details inside which i have parameter id of my resource. I want to retrieve the resource values using the parameter id in GQI. below is the closest i could get by achieving it. but im getting error message “Access not allowed”(pasting the whole error message here). help me with what i’m doing wrong here.
var requestMsg = new GetParameterMessage() { ParameterId = parameter.ParameterID };
var responseMsg = _dms.SendMessages(requestMsg);
var paramInfo = responseMsg.OfType().ToList();
Sending SLHelper.Callback message requests:SLHelperTypes.Messages.InternalMessage over NATS failed with error: (Code: 0x80070005) Skyline.DataMiner.Net.Exceptions.DataMinerSecurityException: Access not allowed.
at Skyline.DataMiner.Net.Helper.Helper.d__12.MoveNext()
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2024
Hi Baranisudha,
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
As this question has now been inactive for a long time, I will close it. If you still want more information about this, could you post a new question?
Ronald Gerard [SLC] [DevOps Enabler]2.06K Posted 17th July 2024 0 Comments
Hi Baranisudha,
The “Access not allowed” exception you get when sending a GetParameterMessage is because your request did not specify from which element to retrieve the parameter.
You can specify the element by also filling in the DataMiner ID and Element ID in the parameter request message (there exists a dedicated constructor for this).
You can find these IDs on the ServiceInfoParams objects in service info.
For a basic scenario, the code could look something like this:
var element = serviceInfo.ServiceParams[0]; // First element
int dmaID = includedElement .DataMinerID;
int elementID = includedElement .ElementID;
var parameter = includedElement.ParameterFilters[0]; // First parameter
int parameterID = parameter.ParameterID;
var request = new GetParameterMessage(dmaID, elementID, parameterID);
var response = _dms.SendMessage(request) as GetParameterResponseMessage;
