How to color chart bars by severity
897 views22nd July 2026
Rodrigo Cerqueira [DevOps Member]63 22nd July 2026 2 Comments
How can I color the bars in this chart based on the severity of the label?
Rodrigo Cerqueira [DevOps Member] Answered question 22nd July 2026
Miguel Obregon [SLC] [DevOps Catalyst] commented 22nd July 2026
Hi Rodrigo,
I am not sure if it is possible to have different colors in a bar chart. Have you tried using a pie chart?
Rodrigo Cerqueira [DevOps Member] commented 22nd July 2026
And how do I choose a specific color for each label index?
Rodrigo Cerqueira [DevOps Member]63 Posted 22nd July 2026 1 Comment
I already tried doing exactly what you showed in your screenshot, but it didn't work. In my case, I only have one column. How can I create a query with a separate column for each severity level?
Miguel Obregon [SLC] [DevOps Catalyst] Edited comment 23rd July 2026
Miguel Obregon [SLC] [DevOps Catalyst] commented 23rd July 2026
Hi Rodrigo,
As mentioned in my previous answer, you need a column per severity. In your screenshot, there is one single column that represents the count of alarms per severity. There is an example in the catalog that you can deploy and use it as reference:
https://catalog.dataminer.services/details/8d26cb0b-ba75-4bfc-8f52-fc721fac4b1d
Miguel Obregon [SLC] [DevOps Catalyst]24.01K Posted 22nd July 2026 2 Comments
Hi Rodrigo,
I investigated a bit further and wanted to correct my previous message: It is possible to change the bar colors based on their value. You can customize the component layout and define conditional colors based on values. Below an example:
For your use case, to set a color per severity, the GQI query result needs a dedicated column for each severity level.
You can find an example about this query in the dashboard Alarm Report.
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 26th July 2026
Rodrigo Cerqueira [DevOps Member] commented 23rd July 2026
I managed to figure out how this GQI works and even made some adjustments to suit my needs. The problem is that it was built entirely around historical alarms, whereas I wanted to use it for a dashboard that deals specifically with active alarms. Do you happen to have another package designed for active alarms?
Miguel Obregon [SLC] [DevOps Catalyst] commented 26th July 2026
Hi Rodrigo,
I had a look at the available ad-hoc data sources and couldn't find one that deals with active alarms in the same way as the ones available in the alarm history report. You could use the ad-hoc data sources available in the alarm report as a reference to build a custom ad-hoc data source that deals with active alarms.
Having a look at other visualizations, is it not an option to use the alarm table component? This visualization already provides you the active alarms. You can group by severity and have the desired alarm count per severity.
Hope it helps.
