How do I move a DVE element to a different view?
Solved2.30K views17th July 2023DVE edit elements Surveyor
Alexander Gorbunov [SLC] [DevOps Advocate]1.27K 3rd February 2022 0 Comments
Before DataMiner 10.1 it was possible to move a child DVE element to a different view by via the Views tab of the Edit GUI of an element card.
I'm not sure since which version it's changed, but now when I edit a virtual element, views in the Views tab are grayed out and not editable. I see this behavior in DataMiner 10.1-CU9 and CU10. I'm using the Administrator account with full permissions, so this is not a permissions issue.
Drag-and-drop editing in Surveyor still works, but this is not very convenient in a system with hundreds of views and thousands of elements.
Is this a bug or is this a feature? Is there another way of moving virtual elements that I missed?
Thanks!
Davy Degrande [SLC] [DevOps Advocate]1.81K Posted 4th February 2022 1 Comment
Hey Alexander,
This looks like a bug indeed, certain fields on a DVE Child elements are allowed through the edit including changing the view.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 16th February 2022
task id to follow up: DCP177415
