Excluding a Specific Element from Parent View Alarm State in Visual Overview
1.14K views5th June 2026alarm shape
Robin Singh358 3rd June 2026 0 Comments
Hello,
We recently encountered a situation with our view structure, similar to the example below:
Romania (Parent View)
  • Basebands List (Sub View)
    • Baseband 1 (element)
    • Baseband 2 (element)
    • Baseband 3 (element)
The status of the "Romania" shape on the map is assigned to the parent view "Romania".
The issue is that "Baseband 3" is always in Timeout and is expected to remain in that state for the next few months. Because of this, the "Romania" shape continuously shows the Timeout state.
Is there a way, either in the Visio shape configuration or elsewhere in DataMiner, to exclude a specific element from contributing to the state of the parent view? Stopping, disabling, or masking the element is not a possibility at the moment.
Thank you.
Jarno Lernou [SLC] [DevOps Enabler] Answered question 5th June 2026
Jarno Lernou [SLC] [DevOps Enabler]6.09K Posted 5th June 2026 0 Comments
Hi Robin,
I don't know the context, but to me this seems like something where masking is appropriate. I think the option of Miguel is a valid option although it also might be dangerous to 'overlook' later.
Another option could be to create a custom alarm filter, save it and use that in your Visio. Linking a shape to an alarm filter | DataMiner Docs
Kind Regards,
Jarno
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 3rd June 2026 1 Comment
Hi Robin,
Is not an option to remove the option 'Include timeout' in the element setting?
Hope it helps.
Robin Singh Edited comment 3rd June 2026
Robin Singh commented 3rd June 2026
Hi Miguel,
That can be a possible solution. Just out of curiosity, is there any changes that can be done in the Visio file to resolve this?
