Do DELT elements function the same way as ‘normal’ elements?
Solved2.62K views11th July 2023DELT
8
Christine Kapembe [SLC] [DevOps Advocate]1.02K 27th November 2020 0 Comments
Are DELT elements any different from elements created on the DMA besides the element ID? Do they function the same way as normal elements? Are there any known issue with associated  reading or writing  to/from DELT elements?
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 27th November 2020 0 Comments
There is actually no such thing as a DELT element.
DELT: DataMiner Element Location Transparency is a feature that allows you to move an element (or service) from one DMA to another one including all dependencies (database data, alarm templates, etc).
The only way to identify an element that has been moved using DELT is the difference between the "hosting DMA id" and the "DMA id".
-Hosting DMA id is the id of the server managing the element
-DMA id is the id of the server where the element was created originally.
