DIS Comparer Suppress functionality not working
Solved373 views14th October 2026comparer suppression
Arman Hadzigrahic [SLC] [DevOps Advocate]74 12th October 2026 0 Comments
Hello, I am trying to manually suppress a major change error that the DIS Comparer is registering, however the option to "suppress" when I right click on the error is greyed out and doesn't work, so I tried to manually add the suppression but when I click "compare" again to refresh it, it is not registering the suppression.
Any ideas on why the button to suppress is greyed out or what am I missing when adding the Suppresion manually.
Thanks 🙂
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 14th October 2026
Pedro Debevere [SLC] [DevOps Enabler]3.52K Posted 12th October 2026 1 Comment
Hi Arman,
Can you try pressing the double sided arrow icon (the icon that is shown between the "Base:" and "Compare with:" text labels) so that version 1.1.0.4 is set as the base version? That should enable the suppress functionality.
Arman Hadzigrahic [SLC] [DevOps Advocate] commented 13th October 2026
Yes, that fixed it, thank you!
