Densite chassis: Miranda IControl General or Miranda Densite connector?
Solved795 views24th July 2026Miranda Densite
Jordy Bekaert [SLC] [DevOps Advocate]2.26K 27th April 2026 0 Comments
Hello, would it be recommended to use the Miranda IControl General (Chassis Densite as DVE) over the Miranda Densite connector for monitoring the Densite chassis?
Jordy Bekaert [SLC] [DevOps Advocate] Selected answer as best 24th July 2026
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.50K Posted 17th July 2026 0 Comments
If you strictly only want to monitor the Densite chassis, then I would go with the Miranda Densite connector. Both connectors provide the same chassis-level monitoring capabilities, including fan status, power supply status, and slot status.
The Miranda IControl General however extends beyond monitoring the chassis by allowing you to monitor the individual cards that can be plugged into the Densite frame.
So depending on how much visibility you need; If chassis monitoring is sufficient, the Miranda Densite connector is the simpler option. If you anticipate needing card-level monitoring now or in the future, the Miranda iControl General connector provides that additional capability.
