DataMiner connection timeout
Solved1.29K views8th August 2023
Jordy Bekaert [SLC] [DevOps Advocate]2.03K 27th July 2023 2 Comments
I’m not able anymore to log in to my local DMA running on a VM due to a connection timeout:
SLErrors shows the following:
SLNet shows the following:
I’m not sure what the problem is. Which steps do I need to take to get this fixed?
Thank you in advance!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 8th August 2023
Edson Alfaro [SLC] [DevOps Advocate] commented 27th July 2023
Hi Jordy, can you share the latest update of the SLDataminer.txt log file? Thanks.
Jordy Bekaert [SLC] [DevOps Advocate] commented 27th July 2023
Hi Edson, of course:
2023/07/27 16:03:42.714|SLLog|ApplyLogLevels|CRU|-1|Log Levels: Info: 0; Error: 0; Debug: 0 (from LogSettings.xml)
2023/07/27 16:03:42.888|SLDataMiner|2964|4556|CDataMiner::CreateLog|CRU|-1|Launching SLDataMiner
2023/07/27 16:03:42.888|SLDataMiner|2964|4556|CServiceModule::LaunchDataMiner|CRU|-1|Starting dependencies…
2023/07/27 16:03:51.490|SLDataMiner.exe 10.3.2321.1738|2964|4556|CRequest::CreateConnection|DBG|0|– SLNetCom object successfully created.
2023/07/27 16:03:51.504|SLDataMiner.exe 10.3.2321.1738|2964|4556|CRequest::AddLocalInfo|DBG|-1|– Added local SLNetCom info: VT_BSTR :
2023/07/27 16:03:51.517|SLDataMiner.exe 10.3.2321.1738|2964|4556|CRequest::AddLocalInfo|DBG|-1|– Added local SLNetCom info: VT_BSTR : localhost
2023/07/27 16:03:51.519|SLDataMiner.exe 10.3.2321.1738|2964|4556|CRequest::AddLocalInfo|DBG|-1|– Added local SLNetCom info: VT_BSTR : 127.0.0.1
2023/07/27 16:03:51.522|SLDataMiner.exe 10.3.2321.1738|2964|4556|CRequest::Init|DBG|0|** Initializing SLNetCom
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.27K Posted 29th July 2023 0 Comments
Hi Jordy,
It looks like something is stuck while the DMA is starting up. If you open Windows task manager and go to Services tab, do you see all SL* services running ?
Have you checked SLDBConnection logging ? Is server restart a possibility ? Feel free to drop an email to techsupport.
