CUBE connection using gRPC
Solved2.36K views1st February 2024
Rajesh Amaragandhi [DevOps Member]40 8th December 2023 0 Comments
CUBE connection to DMA uses Remoting by default (using HTTPS 443 and 8004). But some customers corporate network doesn't permit connections on 8004. They only allow HTTPS on 443.
I suggested to use gRPC mode to use only HTTPS (443). But this setting cannot be changed until CUBE makes a connection to DMA first using 80/8004 to change the Connection settings to gRPC.
Do we have a solution to make CUBE connection stricly and ONLY using HTTPS (on 443) even the first time and not use any other ports?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 1st February 2024
Seppe Dejonckheere [SLC] [DevOps Enabler]3.05K Posted 8th December 2023 3 Comments
Hi Rajesh,
I believe this is possible by changing the connectionsettings.txt file on the DMA. Cube will retrieve this information to determine how it should connect to the DMA.
You can find there necessary information on the connectionsettings.txt here.
Seppe Dejonckheere [SLC] [DevOps Enabler] Edited comment 12th December 2023
Bert Vandenberghe [SLC] [DevOps Enabler] commented 8th December 2023
Indeed, if the connectionsettings.txt defines “* type=GRPCConnection”, Cube should immediately connect with GRPC and only use port 443. Port 80 can be closed.
Bhavana Malviya [DevOps Member] commented 11th December 2023
After this step connectionsettings.txt defines “* type=GRPCConnection
Do we need to restart the DMA?
Seppe Dejonckheere [SLC] [DevOps Enabler] commented 12th December 2023
It is not necessary to restart the Agent after changing this file according to the docs, but I believe it is best to restart IIS.
https://docs.dataminer.services/user-guide/Reference/Skyline_DataMiner_Folder/More_information_on_certain_files_and_folders/ConnectionSettings_txt.html
