“Created:/Modified:” info for Services and for Visio files?
Solved2.52K views11th July 2023creation DB queries service general properties visio logs
Alberto De Luca [DevOps Enabler]5.36K 28th January 2022 0 Comments
I'd need to identify which services and Visios have not been updated in the past 9 months - is there any query I can perform to get the created/modified info directly from the DB?
The "Created/Modified" info is something that is available in the general properties but only for elements - any hints?
If this isn't available yet for views and services, I'm happy to raise a feature request.
Ad interim, I was wondering if there is a known event ID that can be searched in the Information Events table, whenever a Visio gets modified or updated, to fetch data & author of the edit.
Thanks,
A.
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 3rd February 2022 0 Comments
Hi Alberto,
posting this as a second answer as I cant' add images to a comment.
In addition to the filter Pieter suggested, you can add a second filter wildcard or regular expression condition on the value for the Visio file name like below.
This will indeed only be possible during the time window that information events are stored.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 3rd February 2022
