Could not create instance of datasource ….
Solved1.77K views12th March 2025GQI
Jan Palansky [DevOps Advocate]262 2nd November 2023 0 Comments
Hello,
I tried to create custom GQI datasource. It seems valid in Cube.
When I use it in dashboard I’ve got an error:
Error trapped: Could not create instance of datasource IGQIDataSource: …..
Where can I find some logs or more details?
thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th January 2024
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 2nd November 2023 2 Comments
Hi Jan,
Thank you for letting us know. Could you create a ticket and provide us with the following information:
  • The full error message
  • A GQI Recording
    • Create a ‘genif’ folder in ‘C:\Skyline DataMiner\Logging’
    • Refresh your dashboard with the failing query
    • Send us the content of the created ‘genif’ folder
    • Delete the genif folder again
With that information we can further investigate what went wrong.
As a workaround you could try to make a change to the data source and save it. It might be the case that GQI will be able to create an instance again.
My apologies for the inconvenience.
Best regards, Ward
Ward Haeck [SLC] [DevOps Advocate] Edited answer 12th March 2025
Jan Palansky [DevOps Advocate] commented 2nd November 2023
Thank you for quick answer. I sent you an email.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 6th March 2024
Small update: A clearer error message will be shown in 10.3.0 (CU13), 10.4.0 (CU1) and 10.4.4 (RN38686).
