Cisco Switch 9300 Sensor Values
Solved1.82K views7th July 2023Cisco 9300 SFP
Yasser Galal [DevOps Member]88 19th February 2023 4 Comments
I have Cisco Switch 9300, I am using version 5.1.6.18,
I need to show in DMA SFP values ( Optical Power, temperture ,..)
As Show below the values are missing
when I telnet on the switch I got values
I have another Cisco switches 9300 and I can get values
I dont know what I missed when I added this switch,
Please Advise
Thanks 🙂
Rene De Posada [SLC] [DevOps Advocate] commented 19th February 2023
Assuming this is the Cisco Manager connector, I’d advise to check the polling configuration section of the element and make sure there isn’t anything disabled which deals with the sensors.
Bruno Dias [SLC] [DevOps Member] commented 20th February 2023
Can you share the protocol name and version?
Yasser Galal [DevOps Member] commented 21st February 2023
Protocol name : Cisco Manager, Ver 5.1.6.18
Alex Silva commented 25th February 2023
To help troubleshooting if DataMiner is polling
the Parameters / OIDs needed, I suggest using Stream Viewer. It will monitor real-time communication between DMA and element, so you can see if your switch is answering.
Also it is worth searching the element log for errors.
Jens Vandewalle [SLC] [DevOps Advocate]10.01K Posted 19th February 2023 1 Comment
Hi Yasser,
If I remember correctly each switch defines which data can be polled over SNMP. Is it possible that for this specific switch the OIDs aren’t exposed?
Hi Jens,
I have another Cisco switch 9300, and I can get the sensor values,
Attached in the question secreenshot from this Cisco switch
