ChatOps (Teams bot) – Is it possible to create a custom command with an input parameter?
Solved2.56K views20th April 2023ChatOps custom command teams bot
Bruno Dias [SLC] [DevOps Member]2.37K 20th April 2023 0 Comments
If yes, can you please let me know how can I make it?
My goal is to get a parameter value in real-time using the MS Teams bot.
Bruno Dias [SLC] [DevOps Member] Selected answer as best 20th April 2023
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 20th April 2023 0 Comments
Hi Bruno,
Yes this is possible. For each input parameter that you define on your script, the bot will ask for input data.
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 20th April 2023
