Can I use dataminer for PTP monitoring? if yes, how it is helpful?
Solved4.23K views27th January 2023broadcast PTP
pramod Gupta [SLC] [DevOps Member]277 5th August 2020 0 Comments
Is it possible to trace the PTP using dataminer? If yes, is there any recommendation of specific PTP generators? What kind of PTP generators are already integrated with dataminer, if any?
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 27th January 2023
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K Posted 5th August 2020 0 Comments
Also in the DataMiner Help files there are further details on the PTP App. If you want to sit back and relax, dataminer.tv also provides some interesting presentations and demos.
Thomas Gunkel is our expert on this specific domain, so it might be worth touching base with him as well.  There are a number of third-party products supported out of the box by the PTP Solution, but we can integrate any new ones as well.
Marieke Goethals [SLC] [DevOps Catalyst] Edited answer 18th August 2020
