Backup problem
Solved2.11K views11th February 2021backup database Skyline DataMiner Backup
Jeroen Geldhof [SLC] [DevOps Enabler]5.50K 12th January 2021 1 Comment
On a system running 10.0.13 we can see a message !!Backup-process failed, see logging for details.  Unspecified error (-2147467259)
We run a Cassandra database.
Only local backups, no network backup
In SLDMS logging an error can be seen:   "C:\Skyline DataMiner\Backup\TakeBackup.exe" /out "C:\Skyline DataMiner Backups\current_DataMinerBackup.dmbackup" /def LocalBackupPath "C:\Skyline DataMiner Backups" /backupid "PREDEFINEDBACKUPID=1" /amount "3"
In the Skyline DataMiner Backups folder we can see backups present for the last 3 days.
Is this a false error?
Marieke Goethals [SLC] [DevOps Catalyst] Edited question 11th February 2021
Jeroen Geldhof [SLC] [DevOps Enabler] commented 12th January 2021
With the feedback of Alexander we found a file that shouldn’t be there: C:Skyline DataMinerFilesdebug.log, which is in use by SLHelper.exe.
It’s not sure what it is or what it does. We killed the process and removed the file.
Alexander Gorbunov [SLC] [DevOps Advocate]1.19K Posted 12th January 2021 0 Comments
Hi Jeroen,
There is a dedicated log file for backups:
C:\Skyline DataMiner\Backup\Backup.log.txt
There you will probably see more information on what's failing. There are many root causes that produce this error message, finding the exact error in backup logs will help us understand the issue better.
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 12th January 2021
