Backing up a DaaS system
Solved1.26K views26th June 2024backup DaaS
Miguel Barquet [SLC] [DevOps Advocate]1.92K 25th June 2024 0 Comments
What could be the reason I don’t see the option to backup DataMiner in the system to the left (DaaS)?
I already verified I have admin permissions therefore it must be something else. Any relation with DaaS?
Thanks
Bert Vandenberghe [SLC] [DevOps Enabler] Selected answer as best 26th June 2024
Miguel Obregon [SLC] [DevOps Catalyst]22.03K Posted 26th June 2024 3 Comments
Hi Miguel,
This option is hidden in DaaS systems (see DataMiner Docs – DataMiner Cube Feature Release 10.4.6)
Checking DaaS – Data resilience and backups,  data is backed up with a granularity of 1 day.
Hope it helps.
Bert Vandenberghe [SLC] [DevOps Enabler] Posted new comment 26th June 2024
Bert Vandenberghe [SLC] [DevOps Enabler] commented 26th June 2024
Indeed, yet another thing you don’t have to worry about with DaaS :-).
DaaS (and STaaS) is all about focusing on the work which brings real value!
Miguel Barquet [SLC] [DevOps Advocate] commented 26th June 2024
That’s great. How can I restore from a previous backup?
To restore a previous backup, you need to open a support ticket or send an email to daas@dataminer.services.
