Are there any existing integrations between DataMiner and ServiceNow products?
Solved3.24K views10th July 2023integrations IT ServiceNow
Reinout Daels [SLC] [DevOps Member]787 12th August 2020 0 Comments
Are there currently any existing integrations (in either direction) between DataMiner and ServiceNow products, for example creation of tickets in ServiceNow ITSM for certain DataMiner alarms?
Koen Annys [SLC] [DevOps Advocate]144 Posted 12th August 2020 1 Comment
There are 2 Driver integrations for Vendor ServiceNow which might contain what you need. I suggest looking into these.
ServiceNow ServiceNow
ServiceNow Tables
Jochen Dewachter [SLC] [DevOps Member] commented 12th August 2020
“ServiceNow ServiceNow” driver was built with a custom API specifically for DataMiner (developed by Silver Storm). It’s a web service listening for incoming updates on what is called an ‘incident’ in ServiceNow and a ‘problem’ (=maintenance window). It’s not actively polling tickets from ServiceNow. It should also be able to create new incidents into ServiceNow.
Glenn D'Haene392 Posted 12th August 2020 0 Comments
There are tangible references today being used in the market where DataMiner is used for ticket management purposes interfacing with products such as ServiceNow.  By default this is enabled through (1) the DataMiner OSS/BSS Ticketing Gateway and (2) a dedicated ServiceNow driver linking ServiceNow with the DataMiner Ticketing Gateway.  Feel free to get in touch in case you want to learn more about reference projects and/or Ticket management use-cases.
Glenn D'Haene [SLC] [DevOps Member] Answered question 12th August 2020
