Any recommended way to launch a webGUI from a CUBE element card, but in a browser window?
Solved3.28K views27th October 2021Cube default browser embedded web GUI
Alberto De Luca [DevOps Enabler]5.75K 9th December 2020 0 Comments
Wondering if web-links could be launched from the standard element card for a web-GUI, but without embedding the GUI in Cube: plain browser window, possibly not IE, so that also big pages can easily be displayed without the need of additional scroll bars
This could be either a new element page or an option in the embedded web-GUI
(similar to android apps, in practice).
Any future option in Cube clients to achieve this behaviour?
Or would it make more sense to customise protocols to achieve this?
Thanks in advance
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 10th December 2020
Bruno Dias [SLC] [DevOps Member]2.39K Posted 9th December 2020 1 Comment
Hi Alberto, This can be done by creating a Visual Overview for it, using the "Link" shape data.
You can find further information in our DataMiner help - Linking a shape to a webpage
The end-result will look like this:
Jarno Lernou [SLC] [DevOps Enabler] Posted new comment 10th December 2020
Jarno Lernou [SLC] [DevOps Enabler] commented 10th December 2020
Here’s an extract of the DM Help… This might be of interest to you:
The following options can be configured for shapes linked to a webpage:
•UseChrome
From DataMiner 9.6.3 onwards, if you want to make sure the webpage is displayed using the Chromium web browser regardless of the default browser settings in Cube, add a shape data field of type Options to the shape containing the web browser control, and set its value to “UseChrome”.
•UseIE
From DataMiner 10.0.10 onwards, by default Chromium is used to display webpages embedded in DataMiner Cube. To use Internet Explorer instead, add a shape data field of type Options to the shape containing the web browser control, and set its value to “UseIE”.
