Adding a read/write Parameter to a Low Code App
1.41K views16th May 2024low code apps
Joshua Wong [SLC] [DevOps Advocate]649 16th May 2024 0 Comments
I'm attempting to add a read/write parameter to a Low Code app such that I can write to it, does anyone have any advice to give?
Best Regards,
Joshua
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 16th May 2024
Wout Mahieu [SLC] [DevOps Catalyst]12.43K Posted 16th May 2024 2 Comments
Hi Joshua,
There are currently now ways to add single read/write parameters to a Low Code App. Editing parameters is only available for tables using the Parameter Table component.
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 16th May 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 16th May 2024
This is coming in the near future though. We will post an update here once it’s available.
Miguel Obregon [SLC] [DevOps Catalyst] commented 16th May 2024
A workaround for the time being could be adding a Visio overview on your low code app. In the VIsio overview you could add a shape that displays a parameterControl data shape that can perform the read/write.
Hope it helps.
