add an existing element into a view
Solved2.42K views6th June 2024direct view list view
peng fei212 2nd April 2024 0 Comments
Hi
I have an existing element already in a view and a service. And i created another new view. How could I link or add the existing element under the new view?
What i would like to achieve is one element under multiple views. Is that possible?
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th June 2024
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 3rd April 2024 0 Comments
The alternative approach is also to right click in the Surveyor Console and active the “Drag-and-drop editing”.  While active you can drag and drop elements to move them from one view to another.  If you hold the CTRL key while dragging and dropping, you will “copy” the element (i.e. the element will stay in the original view, but you will have it also in the new view where you dropped it).
This is a more efficient way if you want to do multiple of those actions to reorganize and rearrange your elements.
Joshua Wong [SLC] [DevOps Advocate]649 Posted 3rd April 2024 0 Comments
Hi Peng Fei,
That is indeed possible. On the surveyor, you can right-click the element and select “Edit” from the dropdown menu. That will put you on the “edit” tab. Then you can switch tabs to the “views” tab which will show you the views that you have and the view your element is currently in will be checked. You can show the element in multiple views by checking multiple boxes.
This video from our Dataminer Administrator course also details how you can do so (demo is around 29min mark): Elements – DataMiner Dojo
Best Regards,
Joshua
Joshua Wong [SLC] [DevOps Advocate] Answered question 3rd April 2024
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 3rd April 2024 1 Comment
This is possible, you can do this by going to the edit menu of the element and checking multiple views under the ‘views’ tab.
Michiel Saelen [SLC] [DevOps Advocate] Posted new comment 3rd April 2024
Michiel Saelen [SLC] [DevOps Advocate] commented 3rd April 2024
Learning video: https://community.dataminer.services/courses/dataminer-administrator/lessons/elements/
Time in the video 33:20
