Will HTTP/1.1 429 Responses automatically send an Element into Timeout?
Solved1.53K views7th July 2023
6
Michael Wells [SLC] [DevOps Member]502 30th January 2023 0 Comments
Jeroen Neyt [SLC] [DevOps Advocate]2.53K Posted 30th January 2023 0 Comments
Below you can find the logic that is applied to timeout handling in terms of HTTP status codes ranges:
  • 2XX: No timeout
  • 3XX:
    customRedirect enabled and the redirect is not properly handled: Timeout
    customRedirect disabled and the redirect is properly handled: No Timeout
  • 4XX: Timeout
  • 5XX: Timeout
As a result 429 Too Many Requests will automatically put the element in timeout if the last retry of the configured amount of retries on that connection still results in a 429 Too Many Requests or another one in the timeout range.
