Will DIS Inject work with DAAS?
Solved1.49K views23rd August 2023DaaS DIS INJECT
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 23rd August 2023 0 Comments
I’m using DIS Inject often to debug my connectors and automation scripts. Since I need to install something on the server to allow remote debugging, I’m wondering how far I can still use this great feature with DataMiner as a Service?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 23rd August 2023
Bert Vandenberghe [SLC] [DevOps Enabler]9.75K Posted 23rd August 2023 0 Comments
Hi Jens,
That won’t be possible with DaaS since you won’t have access to the nodes doing the job. DaaS is a managed service, meaning you only have access to the DataMiner software, not to the compute running behind the scenes.
PS: you could although open a support ticket to see if we can work something out manually.
Bert
