Which files of an Automation Script Solution add to source control
1.61K views18th September 2025DIS
David Crome [DevOps Member]291 28th March 2025 2 Comments
I am using the Visual Studio DIS extension to develop a protocol and also automation scripts. Adding the protocol Solution to source control (Git) was easy, the structure is easy to understand and every QAction has a cs and a csproj file.
But the Automation Script solution has way more files and I don't know which files I need to add. I imported multiple Automation Scripts to the VS Solution. Do i also need to add the bin and obj folder which every Automation Script has? I guess not, but how did you do that? I did not find anything in the documentation.
Thanks
David
David Crome [DevOps Member] Unselected an answer 18th September 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 10th September 2025
Michiel Oda [SLC] [DevOps Advocate]3.88K Posted 28th March 2025 1 Comment
Hi David
When adding the solution to Git, you can add a gitignore file. You can use the default gitignore for Visual Studio: gitignore/VisualStudio.gitignore at main · github/gitignore
David Crome [DevOps Member] commented 18th September 2025
actually this does not answer my question. I did not ask how I can ignore files with git, but which ones. So how should or can a Automation Scripts Solution project structure look like that anyone can check it out and use it directly. because some files can be ignored and some not, I guess?
