where I can find updated system requirement document for dataminer platform?
Solved3.01K views8th September 2020hardware system requirements
pramod Gupta [SLC] [DevOps Member]277 11th August 2020 0 Comments
Is there a way in Dojo to find the updated hardware requirements for dataminer platform.
pramod Gupta [SLC] [DevOps Member] Selected answer as best 8th September 2020
Miguel Obregon [SLC] [DevOps Catalyst]23.81K Posted 11th August 2020 1 Comment
Hi Pramod,
You can find it in the Documentation section:
DataMiner System Requirements
pramod Gupta [SLC] [DevOps Member] commented 11th August 2020
Great, thanks for quick response!
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K Posted 11th August 2020 1 Comment
It can be found under RESOURCES>Other Resources>Technical Information>DataMiner System Requirements
pramod Gupta [SLC] [DevOps Member] Unselected an answer 8th September 2020
Thanks for quick response, much appreciated.
