When using the Setter = true attribute, will the copy action always be executed first?
Solved1.06K views9th May 2025condition Connector setter trigger write parameter
Michiel Clepkens [SLC] [DevOps Advocate]1.44K 9th May 2025 0 Comments
Hi Dojo
Imagine a read-write parameter combination which uses the setter=true option, and a trigger which goes off when the value of the write parameter changes.
The DataMiner documentation mentions that: “For a write parameter with the setter attribute set to true, the write value will first be copied to the corresponding read parameter before any QAction triggered by this write parameter is executed.”
Can we safely say that the copy action will always be executed first, no mather if the write parameter is used to trigger a QAction or a trigger?
https://docs.dataminer.services/develop/schemadoc/Protocol/Protocol.Params.Param-setter.html
Thank you in advance!
Kind regards
Michiel Clepkens [SLC] [DevOps Advocate] Selected answer as best 9th May 2025
Laurens Moutton [SLC] [DevOps Enabler]9.86K Posted 9th May 2025 2 Comments
When a write parameter has the setter=”true” attribute then:
-First the regular trigger(s) on the write parameter will be executed -> actions executed by these trigger(s) will not see the read parameter value yet adapted to the new write parameter value. Read parameter will still have the old value at this point.
-Then the copy action will be executed to the read parameter
-Then the QAction(s) on the write parameter will be executed -> Read parameter will have the same value as the write parameter at this point
Regards,
Pedro Debevere [SLC] [DevOps Enabler] Posted new comment 12th May 2025
Michiel Clepkens [SLC] [DevOps Advocate] commented 9th May 2025
Thank you for this clear answer Laurens! Much appreciated!
Pedro Debevere [SLC] [DevOps Enabler] commented 12th May 2025
See also: https://docs.dataminer.services/develop/devguide/Connector/LogicParameters.html#parameter-change-events
